Learning Lab
d3769b49
Commit
d3769b49
by
Konrad Hinsen
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Révision de la traduction anglaise
parent
f214aeb4
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
44 additions
and
49 deletions
+44
-49
exo5_python-en.org
module2/exo5/exo5_python-en.org
+44
-49
No files found.
View file @
d3769b49
@@ -15,24 +15,24 @@
# #+PROPERTY: header-args :session :exports both
On January 27, 1986, the day before the takeoff of the shuttle /Challenger/, had
held a three-hour teleconference between the
Morton Thiokol (manufacturer of one of the engines) and NASA. The
a three-hour teleconference was held between
Morton Thiokol (
the
discussion focused on the consequences of the
temperature at take-off of 31°F (just below
0°C)
on
the success of the flight and in particular on the performance of the
O-rings used in
motor
s. Indeed, no test
0°C)
for
O-rings used in
the engine
s. Indeed, no test
had been performed at this temperature.
The following study t
herefore takes up some of the analyses carried out in this study
night
and whose objective was to assess
the potential influence of
the temperature and pressure to which the
seal
s are subjected
O-rings on their probability of malfunction. To do this, we
have the results of the experiments carried out by the
engineers
of NASA during the 6
years preceding the launch of the shuttle
akes up some of the analyses carried out that
night
with the objective of assessing
O-ring
s are subjected
on their probability of malfunction. Our starting point is
the results of the experiments carried out by NASA
engineers
during the six
Challenger.
Data loading
So w
e start by loading this data:
Loading the data
W
#+begin_src python :results value :session *python* :exports both
import numpy as np
import pandas as pd
@@ -68,16 +68,15 @@ data
22 1/12/86 6 58 200 1
#+end_example
The data set shows us the date of
the test, the number of joint
s
each test, the number of O-ring
s
(there are 6 on the main launcher), the
temperature (in Fahrenheit) and pressure (in psi), and finally the
number of identified
dys
functions.
mal
functions.
* Graphical data inspection
Flights where no incidents are found that do not provide any information
on the influence of temperature or pressure on the
dysfunctions, we focus on experiences where in the
at least one seal was defective.
* Graphical inspection
Flights without incidents do not provide any information
on the influence of temperature or pressure on malfunction.
We thus focus on the experiments in which at least one O-ring was defective.
data = data[data.Malfunction>0]
@@ -94,7 +93,7 @@ data
: 20 10/30/85 6 75 200 2
: 22 1/12/86 6 58 200 1
All right, w
e have a high temperature variability but
W
the pressure is almost always 200, which should
simplify the analysis.
@@ -114,17 +113,16 @@ print(matplot_lib_filename)
#+RESULTS:
[[file:freq_temp_python.png]]
At first sight, it's not obvious but good, let's try it anyway
to estimate the impact of temperature $t$ on the probability of
malfunctions of a seal.
At first glance, the dependence does not look very important, but let's try to
estimate the impact of temperature $t$ on the probability of O-ring malfunction.
* Estimation of the temperature influence
Suppose that each of the
6 toroidal seal
s is damaged with the same
probability and independently of the others and that this probability
does not
depends only on the temperature. If
we note $p(t)$
this probability, the
number
of joints $D$ malfunctioning when the flight is performed
at
temperature $t$ follows a binomial law
of parameter
$n=6$ and
six O-ring
$p(t)$ is
number
$D$ of malfunctioning O-rings during a flight
at
with parameters
$n=6$ and
$p=p(t)$. To link $p(t)$ to $t$, we will therefore perform a
logistic regression.
@@ -166,9 +164,9 @@ and the standard error of this estimator is 0.122, in other words we
cannot distinguish any particular impact and we must take our
estimates with caution.
* Estimation of the probability of
The expected temperature on take-off day is 31°F. Let's try to
estimate the probability of
at
O-ring malfunction
he t
O-ring malfunction
at
this temperature from the model we just built:
#+begin_src python :results output file :var matplot_lib_filename="proba_estimate_python.png" :exports both :session *python*
@@ -190,9 +188,7 @@ print(matplot_lib_filename)
As expected from the initial data, the
temperature has no significant impact on the probability of failure of the
O-rings. It will be about 0.2, as in the tests
where we had a failure of at least one joint. Let's get back to the subject
to the set of initial data to estimate the probability of
failure of a seal:
where we had a failure of at least one joint. Let's get back to the initial dataset to estimate the probability of failure:
#+begin_src python :results output :session *python* :exports both
data = pd.read_csv("shuttle.csv")
@@ -202,21 +198,20 @@ print(np.sum(data.Malfunction)/np.sum(data.Count))
#+RESULTS:
: 0.06521739130434782
This probability is th
erefore about $p=0.065$, k
nowing that there is
a primary
seal a secondary seal
on each of the three parts of the
launcher, the probability of failure of
the two
joints of a launcher
is $p^2 \approx 0.00425$. The probability of failure of one of the
so the thrower is $1-(1-p^2)^3 \approximately 1.2%$. I
t would really be
no luck.... Everything is under control, so the takeoff can have
us about $p=0.065$. K
a primary
and a secondary O-ring
both
any
one of the
launchers is $1-(1-p^2)^3 \approximately 1.2%$. Tha
t would really be
bad luck.... Everything is under control, so the takeoff can happen
tomorrow as planned.
Only the next day, the Challenger shuttle will explode and take away
with her seven crew members. Public opinion is
affected and in the subsequent investigation, the reliability of the
O-rings will be directly implicated. Beyond the problems
of internal communication at NASA, which have a lot to do with this
fiasco, the previous analysis includes (at least) a small
problem.... Can you find it? You are free to modify this
analysis and to look at this dataset from all angles in order to
to explain what's wrong.
But the next day, the Challenger shuttle exploded and took away
with her the seven crew members. The public was shocked and in
O-rings was questioned. Beyond the internal communication problems
of NASA, which have a lot to do with this fiasco, the previous analysis
includes (at least) a small problem.... Can you find it?
You are free to modify this analysis and to look at this dataset
from all angles in order to to explain what's wrong.
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
You are about to add
people
to the discussion. Proceed with caution.
Finish editing this message first!
Please
register
or
sign in
to comment
