Premier fichier Rmarkdown
parent 8697ea16
title: "test"
author: "helene"
date: "26 mars 2020"
output: html_document
```{r setup, include=FALSE}
knitr::opts_chunk$set(echo = TRUE)
## R Markdown
This is an R Markdown document. Markdown is a simple formatting syntax for authoring HTML, PDF, and MS Word documents. For more details on using R Markdown see <http://rmarkdown.rstudio.com>.
When you click the **Knit** button a document will be generated that includes both content as well as the output of any embedded R code chunks within the document. You can embed an R code chunk like this:
```{r cars}
summary(cars)
## Including Plots
You can also embed plots, for example:
```{r pressure, echo=FALSE}
plot(pressure)
Note that the `echo = FALSE` parameter was added to the code chunk to prevent printing of the R code that generated the plot.
Markdown is supported
0% or
You are about to add 0 people to the discussion. Proceed with caution.
Finish editing this message first!
Please register or to comment
